Mid temperature blackening smut issue: clear, useful guidance
Summary for mid temperature blackening Discussion
Mid temperature blackening smut issue is the topic of this thread, but the excerpt provided does not include the actual question or any technical replies beyond the forum header. The only named participant shown is adv. Ted Mooney, P.E. RET, who appears as the forum host, but no substantive advice or conclusion is visible in the source excerpt. Because the thread text is incomplete, there is not enough information to summarize the problem, the cause of the smut, or any recommended corrective action without risking invention. The existing meta description suggests the discussion concerns smut that remains despite sealing in a mid-temperature blackening process, but the excerpt itself does not confirm details beyond that. A fuller thread would be needed to identify the practical answer and any specific process guidance.
epi
Q. This is vivek and my query is with respect to mid temperature blackening process where it forms black smut even after dipping it in seal after oxidation.
This smut is not acceptable for wood screws. I request you to help me out with what kind of chemical mixture for mid temp blackening is to be made specifically to avoid smut formation.
Vivek iyer
– Mumbai Maharashtra India
June 8, 2022
A. Hi Vivek. I have a touch of personal experience with cold blackening and hot black oxide, but not with the mid-temperature processes. Further, some people consider mid-temperature to mean slightly below 100 °C whereas others apparently consider anything below 125 °C to be “mid-temperature”. However, I understand that the mid-temperature processes form real Fe3O4 megnetite black oxide surfaces like the hot process, and do not rely on selenium compounds like the cold processes.
Apparently you are trying to formulate your own home-brew rather than buying a proprietary formula, which is also outside of my experience, and not usually done in the USA. But if you want a suggestion on how to improve your formulation I think we need to start with what temperature you are operating at and what your formulation is. Thanks.
June 2022
