Summary for pcb plating process Discussion
PCB plating process and fabrication chemicals are requested here for an educational PCB fabrication setup, but the excerpt only shows the original RFQ from Shah HD in Mumbai asking for help with the process and required chemicals. No technical replies are included in the provided text, so there is no consensus answer to summarize beyond the need for guidance on PCB fabrication chemistry and process steps. The editor’s note says the RFQ is outdated, invites technical replies, and asks readers to post their own RFQs, while also discouraging public commercial suggestions. Because no answerers are named in the excerpt, no advice can be attributed to a specific person.
RFQ. Hello, my friend wish to setup PCB Fabrication Process for educational purpose and require chemicals for same.
Can you help regarding process and chemicals.
Shah HD
– Mumbai Maharashtra
March 23, 2021
