Polyethylene coating on a spring: important question, no answer
Summary for polyethylene coating on a spring Discussion
Polyethylene coating on a spring is the focus keyphrase here, and the original question asks whether a stainless steel compression spring can be coated with up to 30 microns of polyethylene without heating. The thread excerpt only shows the question from Manju Nath, so no answerer’s guidance is available in the provided source. Based on the question alone, the practical issue is whether a low-temperature or non-heat process can deposit a uniform polyethylene layer on a spring geometry without affecting the spring properties. Because no replies are included, the thread does not establish a recommended process, limitations, or whether heating is unavoidable for adhesion and film formation.
November 29, 2014
Q. I need to coat polyethylene on a compression spring.Coating thickness can be upto 30 microns.
Is there any procedure to coat without heat the spring?
Manju Nath
engineer – Inida
