Food Safe Fastener Coatings: Important NSF Reality Check
Summary for food safe fastener coatings Discussion
Fastener coatings for a food safe environment are discussed in terms of a self-drilling screw that needs a dull silver/grey look, 500 hours to red rust, and NSF-related suitability. J Tully explains that NSF-style approvals usually do not work as neat lists of approved platings, and that approved items may be finished products rather than generic coatings. He notes that zinc plating, chrome plating, and electroless nickel can appear in approved end products, but asks whether a coating is NSF approved is often not a simple yes/no question. In the follow-up, J Tully reports reading ANSI/NSF 51 and finding a distinction between direct food contact and splash zones; he concludes zinc plating is not allowed in a food zone. He also learns that Nanomate is only a sealer, typically applied over zinc or zinc-nickel, suggesting similar alternatives may exist under other brand names.
November 17, 2014
Q. I need a plating for a self-drilling screw that achieves the following: 1) has a dull silver/grey appearance 2) meets 500 Hrs to Red Rust and 3) is safe in a food equipment environment or meets NSF requirements.
Customer is currently taking the part with a “Nanomate” coating but are not married to it. I am having trouble finding a list of platings that are approved by NSF.
J Tully
cold-header – chicago, Illinois
A. Hi J. I’m not knocking NSF, but testing/certifying organizations of that sort don’t usually function in a way that leads to neat little lists of approved platings. You’ll find that they have approved some “sold by the gallon” paints and other coatings, and also some coated end products including some zinc plated, chrome plated, and electroless nickel plated items. But I think you will find that questions of the type: “Is zinc plating NSF approved?” don’t have answers because it’s not set up quite that way. (NSF-61 costs about $600, and I don’t have a copy, so I can’t quote it).
My bet is that the major manufacturers of zinc plating and trivalent chrome conversion coatings have either developed or licensed competitive top coats that are roughly comparable to the one you speak of, so you probably aren’t limited to this one — but that if you require NSF approval of your fasteners, there may be some hurdles you’ll have to clear. Good luck.
November 2014
November 19, 2014
thumbs up signThank you. I read through a copy of ANSI/NSF 51 and there is a distinction made between Food zone/direct food contact vs. Splash zone/indirect food contact. Apparently zinc plating is not allowed in a “food zone.” But you are right that Nanomate is merely a sealer and the plater I spoke to who does Nanomate said he typically seals over zinc or zinc-nickel. So my guess is the plating is one of those two with a sealer for extra corrosion resistance and durability, and that I can find something similar but with a different brand name that accomplishes the same.
J Tully [returning]
– CHicago, Illinois
