Summary for electroplating process Discussion
electroplating process questions here focus on what to do after pickling mild steel and before/after plating. Craig Gillan asked whether samples should be baked at 90 °C for 30 minutes, how quickly plating must follow, and whether polishing is needed afterward for a wear test. The reply advises that the substrate should first be scratch-free and absolutely clean, with no water-break after rinsing. For most acid-bath electroplating processes, the work is rinsed well after pickling and then sent directly to the plating tank; a 90 °C bake was said to make no sense in this context. The answerer notes that some steels may need a much hotter hydrogen-relief bake, but only in specific cases such as hardened steel, followed by re-cleaning and a mild acid dip. Post-treatment depends on the coating: some platings need none, while zinc typically needs chromate conversion coating. The answer also says the exact metal being plated matters.
Q. Hi, I was just wanting to ask a couple of questions regarding the whole electroplating process. Firstly, I am pickling the mild steel sample using hydrochloric acid. I’ve calculated the concentration percentage I want and the length of time I want to pickle for. I’m just not sure what to do between pickling and electroplating. I’ve heard that I need to put the samples in an oven at 90 °C for 30 mins and then electroplate as soon as possible. Is this true and are there any other ways? Also, after electroplating, what do I do? Do I need to polish the surface after it? I intend to wear test the surfaces using a micro abrasion wear test machine. Any help would be greatly appreciated. Thanks
Craig Gillan
Student – Edinburgh, Scotland
A. Hi Craig. I will try to answer your questions, but as a student doing this type of investigation, you should probably have at least one or two plating books for reference, and from which you can learn in tutorial fashion. Your college library will probably have a whole shelf.
You haven’t mentioned what metal you will be plating onto your substrate, so it makes describing the process difficult, but anyway:
First, the substrate must be free of scratches and absolutely clean before you worry about pickling. The work must show no water-break upon removal from a rinse before pickling or the rinse after pickling.
For most acid-bath electroplating processes, you rinse the work well after picking and then go direct to the plating tank. A 90 °C bake makes no sense to me offhand (hardened steel sometimes has to be baked at about 190°C for several hours for hydrogen relief after picking, then re-cleaned and re-dipped in a mild acid).
Some plating receives no post-treatment, some does. Zinc plating, for example, requires chromate conversion coating. If you tell us what plating books you have available and what metal you are electrodepositing we may be able to point you to relevant sections. Good luck.
November 2014
