Saturable Core Rectifier: Useful, Clear Explanation
Summary for saturable core rectifier Discussion
saturable core rectifier operation is the central question here: Aryeh White describes repeated repairs of an old Hanson-VanWinkle-Munning rectifier but says the team still does not fully understand why it works. He asks why the original control waveform is not DC, how the “brain box” with toroidal inductors, transformers, a transistor, and SCRs manages voltage/current limiting, and why the output starts high after downtime and then falls to the set value over about a minute. Ted Mooney points to the Electroplating Engineering Handbook, saying its explanation is limited but suggests the saturable core acts like a dam with gates, where controlling the primary controls core saturation. He also notes an important caveat: the rectifier must have a load or the voltage can rise to maximum regardless of settings, unless a dummy load or magnetic preloading device is used. He speculates that preloading may explain the delayed drop in voltage after startup.
October 30, 2014
Q. In the last year, I have three times repaired an old Hanson-VanWinkle-Munning rectifier. Despite the best efforts of myself and my team, we still do not understand several aspects of its operation. Put succinctly, we’ve managed to get it in working order each time without knowing WHY it works.
First, we had understood saturable reactors to use DC in their control windings. At some point in the history of this equipment, the original controls were bypassed and a variac fitted to do just that. Efforts to repair and operate this later control system were comically ineffective, forcing us to instead repair the original controls. The original control system supplied a waveform to the saturable core device that was decidedly not DC. Why does this system deviate so significantly from the magnetic amplifier theories of operation with which we are familiar?
Second, we still lack an understanding of how the innards of what we affectionately call the ‘brain box’ accomplish. The brain box is a black metal box containing two toroidal inductors, three transformers, a transistor, and SCRs driven by what appear to be three circuits connected through the transformers to different phases.
The remotely located control panel contains two rheostats which seem to limit voltage and current, with the machine drawing back on the voltage to remain within whichever limit it hits first. At least, that’s my understanding of the machine’s operation. One of my team believes that the control might somehow allow direct limitation on current through some unspecified method of phase-shifting.
Third, if the machine has not been operated for some days, the output voltage will start around 50 VDC, falling rapidly to its set voltage over the course of about a minute. Nobody at the plant recalls the machine behaving this way prior to it having been removed from service a number of years prior to our restoration of it.
All in all, I’m hoping that there’s somebody out there who has an intimate understanding of this dinosaur and can help us backfill our knowledge. Successful as our repairs have been, I still must admit that we are operating blindly, and have simply been very lucky.
Aryeh White
repairman for geriatric equipment – Rahway, New Jersey
“Electroplating Engineering Handbook”
by Larry Durney
EEHcover
AbeBooks
A. Hi Aryeh. The Electroplating Engineering Handbook has half of a large page on Saturable Core Reactors. I couldn’t quite follow it but, looking at the unit, maybe you can. It should be available in good size public or university libraries.
It says the saturable core is equivalent to a dam with gates, and that by controlling the primary you are controlling the saturation of the core. It does note that one disadvantage of this type of rectifier is that it must have a load on it or the voltage will go to maximum despite the control settings, but that this can be dealt with by a dummy load or a “magnetic preloading device”. Perhaps that magnetic preload device requires a minute to get rolling to pull the voltage back down to the controlled amount?
November 2014
Can broken connection cause rectifier to read 15 volts?
Q. My problem is a simple one but it’s important to me since I am new to electroplating. I opened the box of my new plating machine and plugged it in. It’s a 25 volt 20 amp machine. It immediately showed 15 volts; when I tried to adjust it, it would not respond at all — keeping in mind that nothing was attached to the leads yet.
I returned the unit, then the seller tells me he found that the alligator clip on the black lead was broken. My question is would that have caused the rectifier to show 15 volts even when there was nothing hooked up yet?
Richard Courtright
hobbyist – San Francisco California USA
November 18, 2014
A. Hi Richard. Unfortunately, without a full understanding of the circuitry of the particular rectifier, it’s difficult to contradict the seller’s claim. But it’s easy for a rectifier to supply a “stray” voltage of 15 volts if, because of broken leads, there is no load pulling it down. Diodes and triacs are not like off/on knife switches — they usually “leak” stray voltages of very low current.
November 2014
November 19, 2014
thumbs up signOkay, thanks for the info
Richard Courtright [returning]
