Summary for reel-to-reel sulfamate nickel plating Discussion
Reel-to-reel sulfamate nickel plating over copper or copper clad aluminum wire is the subject of a request for a complete process recipe, including time, temperature, pH, and references such as a guidebook or technical data sheet. In response, Ted Mooney says he does not know of any journal article or plant writeup that would provide all of that information, and notes that even if such documents existed, they would likely omit important details because plating shops treat them as trade secrets. He suggests asking a plating process supplier for a similar case study, but cautions that a full process design is not something most people would do for free. His practical advice is to work through the textbooks, develop a proposed process, and then post it for critique, where experts can help refine it in detail.
May 29, 2014
Q. Please provide or suggest process steps including time, temperature, and pH at each step to plate (Reel to Reel Plate) base metal Copper or Copper clad aluminum wire with sulfamate nickel including documented reference such as Metal Finishing Guide Book, or article or technical data sheet describing the entire process.
Vijay Kansupada
Sr. Chemical Process Engineer (Plating & Anodizing) – Columbia, South Carolina, USA
A. Hi Vijay. I don’t know of any journal articles / plant writeups on this subject and, if there were, they would be missing a lot of this info anyway as everyone has their trade secrets. But you might approach your plating process supplier and see if they have a vaguely similar case study for you.
There’s no harm in asking, of course, but when I did plating consulting for 30 years I would have considered this a 1-1/2 day project — so I don’t think anyone in the world is going to do this assignment for you for free. What I can suggest though, is that you go through the textbooks and attempt the assignment yourself (I have heard of you and know you have broad plating experience), and post your proposed solution … then I think you will easily get several experts to critique your proposal in excellent detail here. Good luck.
June 2014
