Electroless Nickel on Bimetallic Part: Important Plating Check
Summary for electroless nickel on bimetallic part Discussion
Electroless nickel on bimetallic Cu-aluminum part is the core issue in this RFQ: Dave Laidig asked whether a precision-machined 6061 aluminum chassis with a pressed-in C110 copper plug could be plated overall with 100-200 µin electroless nickel and 30-50 µin electrolytic gold, noting the bi-metal construction might be problematic. He said electrolytic nickel could be used instead of electroless nickel if needed, and that a copper underlayer would also be acceptable. The excerpt provided contains only the request and no supplier replies, so there is no documented solution or recommendation in the thread text shown. The practical takeaway is that the part requires a plating shop to assess whether the mixed copper/aluminum assembly can be processed as a unit and whether an alternate nickel strike or copper layer would be needed before gold plating.
April 12, 2012
RFQ. I have a precision machined 6061 aluminum chassis, about 2″ x 4″ x .25″, that has a .36″ diameter C110 copper plug pressed into it. I need this part plated in its entirety with 100-200 µin electroless nickel and 30-50 µ in electrolytic gold. I assume this is somewhat problematic because the part is bi-metallic. Can you plate this part? I could use electrolytic nickel instead of the electroless nickel if necessary. A copper layer under the nickel would be OK as well.
Dave Laidig
Product Designer – Mesa, Arizona, USA
