HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
Live! From beautiful Pine Beach New Jersey: Welcome to the world's most popular metal finishing website
topic 54827
Very hard dark grey corrosion on cast iron!
April 16, 2010
Q. Ok, I work for a performance auto shop. We do porting and polishing of intake manifolds, turbos, exhaust manifolds, etc. We use a 120-grit aluminum oxide for blasting media at about 100 psi or a little over for our rust removal on cast iron.
I have been noticing parts of the manifolds, usually in the same areas, have this dark grey layer under the oxidation. sometime it comes off with some patience. other times I can hit the same square inch of area for over ten minutes and it may only reduce it slightly. I thought it was some sort of slag from the casting process but have blasted items clean of the grey crap and re inspected after a year of road use here in MN and its reappeared! Any help on what this advanced stage of oxidation is called and the best method to attack and remove it would be very helpful!
Matt Homes
Porter and Coater - Hopkins, Minnesota
If you have a question in mind which seems off topic, please Search the Site
ADD a Q, A, or Comment on THIS topic START an UNRELATED topicView CURRENT HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2019 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
