HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
Live! From beautiful Pine Beach New Jersey: Welcome to the world's most popular metal finishing website
topic 54169
Removing aluminum arc spray coating from aluminum substrate
January 25, 2010
How can I remove an aluminum coating by arc spray on aluminum substrate? We've tried chemical etching using Nitric acid but no reaction at all. Tried mix acid but since there is some area is coated & some area is not, the acid etches away the base material as well. Tried sand blasting but not really efficient. The bond strength between the coating & substrate is really strong. Tried grinding also but because of design limitation, it's quite hard to proceed.
Can anybody please help suggest any way, chemical stripping without etching away the base material, or any way to crack the aluminum coating for easier removal using sand blasting. Any suggestion is highly appreciated. Thanks.
Elianie Hilmy
Process Engineer - Kedah, Malaysia
If you have a question in mind which seems off topic, please Search the Site
ADD a Q, A, or Comment on THIS topic START an UNRELATED topicView CURRENT HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2019 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
