plating, anodizing, & finishing Q&As since 1989
Repairing Fibreglass Acid Bath
January 1, 2009
We have just emptied our 750 litre acid bath when it developed a leak. It holds Hydrofluoric and Sulphuric Acid. The construction is MS coated with Fibreglass.
My question is this.
What is the best resign & glass to use for this repair? until a new bath can be sourced and manufactured.
Metal coating shop - Brisbane, Qld Australia
January 8, 2009
Hi Michelle,
Who in der Hell said that frp would be good for HF acid?
Surely there are some good hd Pe suppliers using moulded
tanks in your neighbourhood, try them !
Further, frp tends to wick ... osmotic attack .... hence
structurally the m.s. side would be attacked.
For an el quicko build up, use epoxy. But first of all
grind down the attacked areas.
Freeman Newton [dec]
January 15, 2009
I agree that FRP is not suitable for acid solutions containing HF, but, with a PVDF surfacing veil inside the fiberglass, bonded to it with epoxy and covered with a gel coat of epoxy, it may work for many years.
Lyle Kirmanconsultant - Cleveland Heights, Ohio
January 27, 2009
Thanks Guys, for your response, we have repaired the tank and is holding well. Contact has been made with a business who has done lots of work building tanks for HF, The repair was done to their spec.
Michelle Sindholtpowdercoating shop - Logan Village, Queensland, Australia
February 1, 2009
My chemical bath dimensions :length 14 metre x width 1.5 metre x depth 2.5 metre. It is for degreaser; concentrated hydrochloric acid; flux; molten zinc; water.
At present the material is constructed from reinforced concrete.
My question is how to detect any leakage before it becomes a hazard.Something similar to an early warning signal to alert the user.e.g. there is a cracked in the holding bath.
