Q&As since 1989
White patina on brass/copper
Q. Dear sirs, Did anybody try to make white patina on brass? I heard there are some advice in books of Ron Young, but, unfortunately, I cannot find these books. Maybe, somebody has some experience in this area --I mean your experience in white patina on brass, not books of Young :-)
Thanks beforehand, Sincerely,
ALEX WOLF- MOSCOW, RUSSIA
Ed. note: Ron Young's "Contemporary Patination" might not currently be available new, but copies are available used: Contemporary Patination [affil link on Amazon]
Q. AS I UNDERSTOOD, NOBODY IS EXPERIENCED IN WHITE PATINA HERE. MAYBE, ANYBODY MEET YELLOW PATINA ON BRASS/COPPER? SINCERELY, ALEX
ALEXANDER VOLKOV [returning]- MOSCOW, RUSSIA
A. Alex - In order to apply a white patina to brass, you would have to find a salt of copper that is white. The typical patina is copper carbonate which is a pale greenish salt, and used because it is not too soluble. Copper sulphate, copper chloride, copper nitrate [affil links], are all in the green color family and not what you are looking for. My suggestion therefore, may be to find a paint system to coat the brass and then relieve it if that is your final finish.
Ed Budman [dec]
- Pennsylvania
A. Hello, I don't know if it is an old subject but about the white patina: difficult to obtain. Forget the bismuth but you can use zinc nitrate around 50 to 100 gram/liter; it is a torch patina. To reinforce the white you can play with a water solution of titanium oxide and alternate the two solutions.
What I have tried also is first layer of brown (ferric nitrate) and titanium oxide with acetate poly vinyl. Not a real patina but the result is sometimes more important.
good luck
- Brussels, Belgium
September 25, 2009
