Q&As since 1989
Masking solution for Anodising
Dear friends we are need of masking solution to mask the aluminium parts to be hard anodised(hard coat).Now we are using locally available pvc based masking solution which is not giving good results.also we have tried with pvc tape which is also not ok.Any good quality masking solution suitable for hard coat supplier needed. thanking you, d.elangovan sri balaji enterprises, India
ELANGOVAN- INDIA
We have excellent results with a lacquer based product called Miccroshield. I have used the pvc products, and get much better results from the Microshield. The distibutor we get it from is Xytek.
Marc Green
anodizer - Boise, Idaho
YOU MAY USE POLYESTER TAPE WITH MIL THICKNESS WITH SILICONE ADHESIVE OF AT LEAST 1.5 MIL THICKNESS SUCH TAPE YOU CAN FIND WITH MANY DISTRIBUTORS OF MASKING PRODUCTS.
Kissak Sarajian- Menomonee Falls, Wisconsin
One of the easiest way could be using Wax. Usually these waxes are melted and applied on the place where anodising is not required and subsequently part is anodised. After anodising these waxes may be removed in hot water.
Dr.Rudreshmetal finisher - Bangalore, India
finishing.com is possible thanks to our supporting advertisers, including:
