Free personalized metal finishing help!
Sculptor Needs Corten to Rust!
(-----) February 20, 2008
What is the most economical and efficient way to remove mill scale from a Corten steel fence? The fence has been in place for 8 months and still looks like scroungy untreated steel. The panels are 10 feet tall and are mostly solid 3/16" thick plate. Acid treatments are out because of containment issues. There is no expectation of a smooth texture so a grinding stone would work, but would a paticular type of sandblasting process or specific abrasive work better?
Thanks for your help.
Dave
Sculptor - Corpus Christi, Texas
In order for my weathering steel planters to develop that classic Cor-ten rusty look Do I need to remove the mill scale or treat the surface in any way before installation?
November 25, 2015Q. I'm making 2 large planters of 3/16" A588 weathering steel. It looks like it has a fine and uniform coating similar to mill scale present on typical hot rolled steel except that this coating is a bit more brownish. Is this mill scale or the beginning of the oxidation process?
I'm wondering if I need to prepare the surface in any way for a uniform oxidation to take place.
Also wondering what I can do do make my welded areas rust in a way that matches the core-ten. Is there a special grade of welding wire that I should use? Will pickling the steel with acid to hasten the oxidation have undesirable results?
Artist/Designer/Fabricator - USA
