No registration or passwords; no pop-up ads -- just aloha, fun, & answers.
(as an eBay Partner & Amazon Affiliate earns from qualifying purchases).
Advertise
pub  Where the
Q&As since 1989
How to Mirror Finish Alumina Ceramics
Current question & answers:
Q. Hi.
We manufacture technical ceramic parts for various industries, we have a requirement for mass finishing alumina ceramic rings to mirror finish.
We have Vibro machines installed but we are not able to go beyond matte finish. Can you guide us?
Gaurav athawale
- Anand Gujarat, India
January 13, 2021
A. Might want to try dry burnishing after your first step. However, if you are lower than a 20RMS you can skip your first step altogether. Dry burnishing media consists of dry organic media and porcelain ball media. If you need more info, get in touch.
tony kenton
AF Kenton
March 13, 2021
Cleaning of alumina ceramics
Q. I HAVE CERAMIC BEADS THAT ARE ONE INCH LONGX1/8 DIA WE USE THEM IN A HEAT TREAT FURNACE AS THERMOCOUPLES THEY GET A COATING ON THEM AFTER A WHILE THEY SHORT OUT DO YOU KNOW OF ANYWAY TO CLEAN THESE.
THANKS,
THIS CERAMIC IS MADE OF PURE ALUMINA.
JAMES LOVELAND
AMERICAN BRAZING - WILLOUGHBY, OHIO
A. You didn't indicate what coating was causing the electrical conductivity ... is it safe to assume the surface film is metallic? An acid rinse followed by bake in air or oxygen at a suitably high temperature to oxidize the residual metals should do the trick. Alumina can take 2000 °C for extended periods(mp 2030 °C). If the residual metal is tin, the oxide will be conductive, but the oxide is also soluble in sulfuric acid and can be removed that way.
Dale Woika
Surface Conversion Sciences - Bellefonte, Pennsylvania, USA
Stripping yttrium from ceramic substrate
Q. Need help ASAP. I work for a company in Austin TX and I need help stripping yttrium from a ceramic substrate. The yttrium was put on to protect the ceramics now my company is finding that it interferes with one of our coating procedures. I need to be able to strip the yttrium from the ceramics without etching the ceramics.
Thank You,
Chris St. Peter
plating, stripping shop - Austin, Texas
A. I used to strip Yttrium Oxide coatings using a 50-75 ° solution of Aqua Regia (HNO3 + HCI)on glass and epoxy resin (Fiberoptic cables) most likely this would also etch off the Yttrium metal (I'm assuming that it is metal). The Aqua Regia is a very strong acid mixture but has little effect on most ceramics (Alumina, glass, etc..).
Kevin Dowhower
- Lompoc, California, USA
Consult'g, Train'g
