A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
(current
topics)
topic 4772
Electroless Nickel is Staining!
(2000)
We are a small shop and have just introduced an electroless nickel line. The problem we are having is that in plating leaded steel (alloy 12L14) we are getting a delayed tarnish/stain that appears to be coming from the racked hole. Does anyone happen to know what is causing this and how to prevent it? Thanks for any insight you are able to give us.
Katherine Carr
Metal Finishers - Lilburn, Georgia USA
(2000)
No one can tell with out seeing the process and the part.
A high probability is process chemicals leaking out of the hole during or after the plating tank step.
Flush out the hole with a lab squirt bottle after the first post plate rinse and see if it goes away.
Plug the hole if possible. If not, dunk the racked parts in a clean rinse tank several times. This will fill the hole with water and reduce the amount of chemicals in the hole.
Increase the agitation in the post plate rinse tanks.
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
