-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 4739
Nernst Equation as it applies to brass etching
I was reviewing your comments regarding the Nernst Equation today in the sci.chem.electrochem newsgroup. I have a question regarding the last paragraph of your response.
..."As a second application example, consider alloy plating, say brass. This involves simultaneously plating with zinc (a very active metal) and copper (a very noble metal). If we could not complex the copper, tieing it up so that the free ions are extremely few, the plating would end up 99.99+ percent copper--not much of a brass. The Nernst equation tells us how much we have to tie up the copper so we can plate alloys of useful ratios."...
As a hobby, I have some done some electro-etching of thin (0.1") brass (70%Cu 30%Zn) to create model locomotive number plates. I use CuSO4 for the electrolyte and a 5VDC power supply and it works great. This is just a hobby, but I like to understand the technology I am working with. Seeing as how electro-etching is the reverse of electro-plating, I realize that your answer doesn't directly apply to me, but got me thinking about changing my electrolyte to a solution of CuSO4 AND ZnSO4.
Question # 1. Should I change my electrolyte to CuSO4 and ZnSO4?
Question # 2. If yes, should I use the same percentages (by dry weight) of these salts as to the brass metal elements. Could you explain how the Nernst equation would apply here?
Question # 3. Would this electrolyte give different surface results?
Question # 4. Are there safety and disposal concerns?
Thank you for your time and effort. I really enjoy reading and learning from your site.
1. No, I wouldn't change if it's working.
2. Actually, zinc will want to dissolve into solution first because it is a far more active metal, and your etching solution will soon contain a lot of zinc. In fact, it will be exhausted when it has a lot of dissolved zinc in it and little dissolved copper left.
3. I don't think so, it would be like working with a depleted copper sulphate solution.
4. Copper is a strong biocide. They put it in lakes to halt algae growth, and in old drain pipes to discourage roots. But I don't think it is categorically regulated. Ted Mooney, Teds signature
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
