-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 4605
Spots on acid zinc plated parts
Q. Black spots appears on our barrel acid zinc plated parts, can anyone help us on this matter?
Thank you for your time
andrew kaw
- manila, philippines
A. This sounds like a classic case of iron contamination. See "Improving Your Chloride Zinc Plating Operation". Regards,
Ted Mooney, Teds signature
Pine Beach, New Jersey
A. Dear Andrew,
Firstly (a) do read the article Mr Mooney has suggested. Meanwhile if after you treat the bath for iron and the problem still persists then (b) try reducing the Voltage. If efficiency drops, then increase anode area.
If the reduced voltage has helped without any problems, then (c), sigh with relief. If not then (D)check the Barrel rpm which may be too low. Increase the barrel rpm between 14 to 16 rpm whatever suits the hole size and current with giving your parts black spots.
smileyIf all the above efforts fail, then do the opposite of everything above and charge more for the black spots without giving them away for free!
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind supporting advertiser
Bangalore, Karnataka, India
saify logo
July 7, 2013 -- this entry appended to this thread by editor in lieu of spawning a duplicative thread
Q. Hi experts,
I'm running acid zinc barrel plating and currently facing the barrel holes mark on my plated parts.
I suspect this problem is caused by the barrel rotation speed! Is it true?
barrel hole mark on plated part
Lovely thanks for help.
Sng Horng
- Penang
July 2013
A. Hi Sng. We appended your question to a similar thread. This looks like a classic case of iron contamination in your acid zinc plating tank, not a problem caused by the rotation speed. Good luck.
Ted Mooney,
Teds signature
July 22, 2013
A. Black marks in barrel plating of acidic zinc are a results of too high divalent iron in the solution.
You have to oxidise the iron (by hydrogen peroxide or air) and filter the sludge.
sara michaeli
sara michaeli signature
Sara Michaeli
chemical process supplier
Tel-Aviv, Israel
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
