A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 4506
Need to Degrease and Pickle in one bath.
(2000)
Hello,
We plate Mild Steel with zinc and nickel chrome plating and of late are examining the possibility of doing away with alkaline soak cleaning + anodic cleaning and subsequent rinsing before pickling. The idea is to combine the degreasing and pickling in one operation, thereby minimising rinse water and also obnoxious HCl fumes .
We are trying some home brews by mixing HCl with a neutral Ph anionic surfactant which is doing up to 85 % of the job but does not as good a job as the conventional alkali + acid dip.
Any ideas as to what else may work ? If we were to use anodic current in our mixture, what material could we possibly use as a cathode for it to survive the HCl Cathodic current ?
An alternative home brew which works will also be most welcome.
Many thanks in advance,
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind supporting advertiser
Bangalore, Karnataka, India
saify logo
(2000)
Don't you just hate it when someone says something can't be done. And then you ask them why, and they just say because it hasn't been done before? It's not going to work.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
(2000)
It's a good thinking indeed. You cannot process through electrolytic way. If you have high oil load on components then better to go via a manual solvent wipe on before going to pickling cum degreasing process. further, you can also try with an non ionic emulsifier like nonyl phenol ethoxylate with 9.5 to 20 moles of ehoxylation. Hope for the best.
DR.D.SEN
- calcutta 700001
(2000)
Dear Mr Mooney and Mr Sen,
I am continuing my trials and you are unfortunately right in your predictions that the anodic is not working, but however I am having a fair amount of success with degreasing and pickling with immersion alone. My main idea is to have a comfortable working relationshp with HCl inside my plant sans the fumes .
Dr Sen, the non ionic emulsifier recommended by you is not locally available. Does it have an expanded name or can you recommend a supply source? Does it have to be added to the HCl and how much ?
Thanks again,
Khozem Vahaanwala
Khozem Vahaanwala
saify logo
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
