A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 4479
Purification of copper
(2000)
Hi
I'm doing a piece of work on the purification of copper by electrolysis. I'm using a CuSO4 electrolyte and 1 amp of current for a varied length of time. My question has two parts. Firstly, can anyone explain to me in as much detail as possible how Faraday's Laws affect this experiment. Secondly, why do bubbles appear in the electrolyte after only a short amount of time (reducing the current). Is this to do with polarization? Why does it happen?
I am VERY grateful for any help that can be given.
Will
Will Evans
- Plymouth, Devon, England
(2000)
Purification of copper sulfate by plating is a "maybe".
Assuming that you are in an acidic condition, Dissolved copper sulfate will give an acidic condition, many trash metals will plate out also. The key to purification is to use the lowest current that will plate out the copper and not the tramp metals. This will be about 1/2 an amp per sq ft of cathode area with lots of agitation, air or mechanical.
Since this is a lab sized project, you will need a tiny power supply with an ammeter that reads in 0.01 or less amps. A VOM (amp meter function)can be put in series with the load and is a very precise LOW amp meter. Radio shack cheapie will do.
The bubbles are because you have exceeded the hydrogen and oxygen overvoltage potentials and are generating O2 and H2 gas, an explosive mixture that a spark can set off.
Faradays Law holds very true until you start generating gas, then some of the amperage is going into electrolysis of the water. Go high enough and you can generate chlorine gas if you are using tap water.
The crux of both Faraday's laws is that the element deposited on cathode is proportional to the current passed, time during which the current has passed and the electrochemical equivalent of that element. During electrolysis conducted possibly you have used insoluble anodes. This has possibly caused oxygen bubbles to get built up on the anode causing an additional resistance. This has reduced your current flow.
Chitra P Kamath
- Silvassa, India
(2006)
During the purification of copper (through the process of electrolysis of copper sulfate) where does the sulfur and water (H20) go? Please help me! (year 11)
Lazar P.
- Perth, Western Australia, Australia
(2007)
They just stay where they are, Lazar. The copper is electroplated out of solution and the sulfate and water remain in the solution.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
