No registration or passwords; no pop-up ads -- just aloha, fun, & answers.
(as an eBay Partner & Amazon Affiliate earns from qualifying purchases).
Where the
Q&As since 1989
Adhesion problem on Kovar
Need help on this : I am plating electroless nickel on Kovar material, I use a 2% HF dip before a 50 degrees warm dip in 50% v/v HCl, however, I have adhesion problem and skip plating too.
any advice will be appreciated.
James lai
- singapore
The only way I have found to be able to successfully plate on Kovar is to use a Watts nickel strike before the electroless.
John L Reid
- Brisbane, Qld, Australia
