STEEL FOR SEA WATER APPLICATION
We are looking for a steel/stainless steel material which does not corrode in sea water when exposed for long durations and under high stress and room temperature. This will be used to simulate deep sea conditions for testing of components.Alternatively suitable coatings may be suggested on steel surface.
Prof Prashant KumarDepartment of Mechanical Engineering
I I T, Kanpur India
5 Feb 2000
A US Navy deep dive unit used a lot of 316 and 316L that had been passivated or electropolished. If in contact with other metals, it may/will rust.
Dear sir,
any ss/316 not withstand under the sea water/salt water.
you coat the 50 micron of PTFE/PVDF/POLYAMINE/PFA/FEP/SILICONE etc.corrosion res.flouoropolymers. There are many branded coatings are available.in INDIA. xylan/greblon/teflon/rilson. urs nearest DElhi ar in Gujarat available that coatings.
kalyan dhakane
Kalyan Dhakane
Mumbai, India
