-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 4350
Hard anodizing testing methods and surface characterization
Q. I need some information about (hard) anodized aluminum layers, especially testing methods, layer characterisation (mechanical properties, morphology etc.)
Kerstin Baldus
- Kaiserslautern, Germany
A. Aluminum anodizing is an electrochemical conversion of the surface metal into a crystalline aluminum oxide. In Hardcoat anodizing, the processing parameters are adjusted to create a thicker and denser coating than commercial anodize. The thickness is easily measured with eddy current devices. Hardcoat is typically 40 to 60 um thick verses 2 to 15um for conventional anodize. The density determines the wear resistance or "hardness" of a coating. Commercial anodize is normally not wear tested. American hardcoat standards, Mil-A-8625 [link is to free spec at Defense Logistics Agency,] Type III and AMS2469 [link by ed. to spec at TechStreet], use a Taber Abraser to measure the coating weight lost in a standardized wear test. European hardcoat standards, ISO 10074 [link by ed. to spec at TechStreet] and BS 5599 [link by ed. to spec at TechStreet], use an abrasive wheel or Suga tester as the primary test to measure coating weight and/or thickness loss. This test is much less standardized as many of the test parameters are left to to discretion of the tester. All these specifications set minimum wear resistance standards for hardcoat anodize. Due to limitations of these wear tests, Vickers microhardness testing is occasionally substituted. Typical hardness values are 300 to 600HV.
Chris Jurey, Past-President IHAA
Luke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
luke engineering banner
Q. We build rowing shells & accessories. A subcontractor hard anodizes our aluminium alloy 'riggers'. We're at the top end of our market but the anodizing has become a problem:- Our riggers are made by connecting seamed 5251 & drawn 6082 tubes with spigoted LM4 (Al Si5 Cu3) castings (resin-bonded joints). The anodizer receives them clean & Scotchbrite abraded. Most anodizing over some years has been good, but variability has increased of late: some batches have pale, fragile film on the tubes which fails the tape-peel test! The subcontractor blames the metal, esp. the 5251, but has had good & bad results from identical tube batches. We think that his QC is failing. But what, in reality, is happening? We're going up the wall & would welcome expert comments, please!
Carl Douglas
Carl Douglas Racing Shells - Staines, Surrey, UK
Q. During hard anodizing of kitchen utensils deep drawn from AA3003 alloy the colour goes from dark grey to light grey on the same parts. What should be done to obtain the colour just dark grey during hard anodizing.
Yasar Bayraktar
Eti Aluminium - Seydisehir, Konya, Turkey
Q. Hello!
Firstly, my English is not so good, sorry. I have already finished chemist department in Cukurova University in Turkey and I am going to go on with my education to a masters degree.
I am going to investigate about hard anodizing and in this subject you can help to me the best.
If you can help me about this subject, in fact I will very happy and successful .
thanks I will wait your help
Gürbüz Comak
Cukurova University - ADANA, TURKEY
A. Buy some good books like ASM Metals Handbook (Volume including surface finishing of aluminum) and others. They can be found on line.
Guillermo Marrufo
Monterrey, NL, Mexico
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
