A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 4348
Creation of microchannels in Cu
(2000)
I am trying to create several rectangular ducts in a block of Cu. The ducts should be on the order of .1mm X .1mm and about 50mm long. The walls of the ducts should be very smooth (roughness around 1um RMS). I have thought about etching these but controlling the depth seems to be a problem. Maybe electroplating the walls of the ducts onto the block might work. Does anyone have any experience doing such things. The masks for the electroplating would have to be very, very accurate.
Please help.
peter stark
arthur d little - cambridge, Massachusetts
(2000)
The process of actually making a part rather than a coating is called 'electroforming' and you may find more info using that keyword. Accuracy of masking and electroplating shouldn't be problem, although it is far easier to get a smooth surface on the inside of an electroform (the surface you are electroforming onto) than to get a smooth surface on the outside (the surface that is still wet with plating solution as you pull the part out of the plating tank).
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
