A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 4318
Some problems in chrome and nickel strike....
(2000)
I am a plant chemist in a bright nickel chrome plating shop. Sometime we come across with strange problems in chrome bath. For example what causes the spectrum type color on the part after chrome. We plate over stainless steel. Also sometime we see dark gray spots on the lower current density area after chrome. I tried chrome pre dip and it worked. But our supplier says it is high iron content in nickel strike. It would be appropriate to mention a bit about our nickel strike. It has about 225g/l nickel sulfate, 90 g/l nickel chloride and 45 g/l of boric acid and pH about 2.5 And believe me it is a strange strike tank and is very moody (laugh). Sometimes when we have roughness problem just turning the current off works well( in the strike tank). Whereas in my earlier years of plating I learnt that vigorous air agitation is helpful in eliminating roughness problem. Anyone with some suggestions is most welcome.
Hemant Kumar
Hemant Kumar
- Florida, USA
(2000)
The spectrum like colour on the chrome deposit is due to low sulfuric acid.
Dark grey spots on the high current density can be due to high sulfuric acid, low temp. or low chromic acid.
Grey spots on low current density or anywhere else for that matter, is due to nickel passivation.It can be related to organic contaminations in the nickel solution ( by the way, you mentioned you strike nickel but did not mention the bright nickel), poor rinsing and long time between nickel and chrome. You can try to activate the nickel deposit in a cathodic ( with or without cyanide) cleaner prior to chrome plating.
sara michaeli
sara michaeli signature
Sara Michaeli
chemical process supplier
Tel-Aviv, Israel
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
