-----Hexavalent chrome conversion coating
We use a hot rinse; 10 min at 55 - 65 grd C after Chrome Conversion Coating of aluminium. ("Bleaching", see ASTM B449 ). The salt fog and paint adhesion properties are the same as a CCC, and the peel + humidity resistance (Wedge test method for testing paint adhesion properties) is slightly better. Maybe this bleaching will also work on a zinc plating.
Rob Wilgenkamp- The Netherlands
Huh? Hello, Rob. Maybe this was intended as an answer or followup on another thread, rather than the start of a new thread? Sorry, but I can't figure out where you're going :-(
