Q&As since 1989
Machining and hardening Beryllium ?
Finishers,
I'm looking for a firm ( UK )that can hard anodise beryllium. I'm pretty sure that the chemisty of beryllium would support this, though I'm not entirely sure. Even better, I would like a TiN coating, but I'm not sure if that can be done. I also require some basic machining of the part first. ( Yes, I realise that Be is potentially toxic if mishandled ... )
Any ideas ? Many thanks.
Simon Convey- London UK
The anodising process that you should try is called KERONITE. This has been tested very successfully on AlBeMet (an Aluminium/Beryllium alloy) and produced excellent corrosion and wear resistance and very good adhesion too. No risk from Berylliosis due to the aqueous nature of the process.
Robert Altham- Cambridge UK
