A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 4187
Surface finishing of Titanium Ti-6-4
(2000)
Greetings,
I am trying to locate companies who deal with surface finishing of Ti-6-4. We have surgical implant pieces with a surface of 125-250 micro and would like to get the finish down to about 60 micro. All I've come up with so far is companies who use vibratory tubs. Any suggestions?
Ethan Fricklas
- Narragannsett, Rhode Island
(2000)
Nitric acid and Hydrofluoric acid mixtures exhibit some chemical polishing capabilities. This is a dangerous mixture. Nitric-Ammonium bifluoride might do the same.
It is a long jump for chemical polishing to go from 320 to 60. It might not be possible.
I would call up Metal Coating Process Corp., they could give you information about electropolishing of Ti.
Achieving a 60 microinch finish on Titanium is not that difficult when using centrifugal barrel equipment and the appropriate media. In fact much finer surfaces can be developed if a process is used that has several cycles with successively finer abrasive materials. If the part shape lends itself to it, one of the newer processes available (Turbo-Abrasive Machining - TAM) has been known to reduce as-ground or as-machined surfaces to 20 Ra and below in cycles of less than 5 minutes
Dave Davidson
process labs - Bartlett, New Hampshire
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
