Q&As since 1989
Low friction coating (µ from 0.2 to 0.25)
I'm a young engineer in materials and mechanics. I'm looking for a low friction coating (friction coefficient from 0.2 to 0.25) for a new friction application to transmit power.
pressure: 0 - 12 MPa
sliding speeds: 0 - 2.5 m/s
ambient temperature:-20 to +90 °c
substrate : steel
antagonist : steel
surface temperature estimated at 100 °c
plane on plane
I thank you very much for your response.
Jerome MELEARD- Arcueil-France
Sounds like a good description of hard chrome plating, Jerome! Plate one of the two items with hard chrome. Good luck.
Composite Nickel-Teflon coatings developed for high lubricity and available from a number of electroless nickel chemistry vendors may work well in your application.
Good luck,
"PlaterB" Berl Stein
NiCoForm, Inc.
Rochester, New York
Dear Mr. Meleard:
There are excellent friction reducers that are bonded onto various metals. It is a finely dispersed Teflon emulsion that coats the metal from an aqueous solution (no organic solvents). A hot air dry is all that is needed for final bonding.
Ed Budman [dec]
- Pennsylvania
