Closed Loop Nickel Rinses: Smart, Safe Control Tips
Summary for closed loop nickel rinses Discussion
Closing the loop on nickel plating rinses is discussed as a practical but carefully controlled option, not a simple fix. Jim Conner asks whether he can stop treating bright nickel rinses, use evaporators, and return filtered, carbon-treated rinse water to the bright nickel tanks, since he believes nickel efficiency and Faraday’s law should limit losses. He worries that reducing anode area might cause anode polarization and lead to costly chrome-plating failures. In response, Sara Michaeli says closed-loop systems for nickel plating have been popular for years, but bright and semi-bright lines need separate loops. She also suggests the real issue may be why nickel concentration is increasing in the first place, asking about anode type, whether R or S nickel is being used, and whether chloride is too high and causing excessive anode corrosion. The thread also mentions Ted’s software, Perfect Rinsing, as a tool for calculating evaporation and rinse requirements.
Q. I run a large job shop that has (9) 2200 gallon nickel tanks. Six of them are semi-bright and three of them are bright. I periodically have to decant the nickel solution due to metal growth within the baths.
One of my associates has told me that this is a needless waste of nickel and by simply reducing the anode area we will reduce the amount of nickel build up in the baths. He feels that we could close the loop on our bright nickel tanks with evaporators and feed all of the filtered, carbon treated rinse water back into the bright nickel tanks. Since we don’t rinse between semi-bright and bright nickel that is the only option we have obviously.
I know nickel is 97% efficient and Faraday’s Law is pretty straight forward. I’ve heard varying opinions about this and people have warned me about anode polarization among other ills. My problem is that I can’t afford to have anode polarization occur and have chrome plated bumpers peeling by the hundreds. I suspect that I wouldn’t know about it until it was too late.
I don’t have much drag out and even if I did, with a closed loop system I would recover all of the nickel anyway. The idea of not treating nickel rinses anymore is very intriguing but something just doesn’t add up here. Am I missing something obvious? If he’s wrong, it could cost me thousands. If he’s right, I’m wasting thousands now. Anybody out there have some answers? Thanks for the advice!
Daryl Spindler
Daryl Spindler, CEF
decorative nickel-chrome plating – Greenbrier, Tennessee
A. Daryl,
although your tanks are relatively large compared to most shops it is possible to cut the nickel to almost zero. The first thing I would do is a mass balance to see what the drag out content is. This will tell how much water is needed to maintain a reasonable nickel level in the rinses. Second, do an evaporation study to see how many gallons per hour are being evaporated by the bright tanks. Once you have the evaporation rate and the gallons per hour needed to keep the rinses clean it’s just a matter of choosing the right technology to achieve a balance. Certainly carbon treating the drag out rinse is a good idea. You may want to step up your dummying schedule due to an increase of contaminants from the drag out being added back. We’ve been doing this for years on several bright nickel processes without any problem.
I would recommend reading the chapter on rinsing in the Metal Finishing Guidebook. It was written by Ted Mooney and it tells you all you need to know to get started. It may even be worth paying him for a few days of his time to evaluate your process since this is his specialty (no…I don’t get any commission!)
jim conner
Jim Conner
Mabank, Texas USA
A. Following Jim’s reply, Ted also has a software named Perfect Rinsing that can make all the calculations for you regarding the evaporation, # of rinses, etc. We use it a lot and it is great. (and just like Jim, I also get no commission). Closed loop systems for nickel plating is popular for years. Of course, you have to use two different loops for the semi-bright ( I assume sulfur free) and the bright line.
Why is you nickel concentration growing? What kind of anodes are you using? I hope that you use R and not S nickel. Or maybe that your chloride concentration is too high and that is causing a high anode corrosion.
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
February 28, 2009
! Thanks for the kind words Jim and Sara.
