Pattern building process for nickel
Hello!
I'm looking for a process for electroplating steel substrates with nickel. I have two purposes, substrate pre treatment to get a smooth surface and secondary for pattern building. The pattern building will be done with some kind of photoresist for masking. The pattern line width is less than 1.5 micrometers.
Do you have any suggestions where to turn to?
Ike Rehnman
Sweden
Sounds like you need a book on electroforming. This is frequently done with sulfamate nickel because it is the closest to zero internal stress of most plated metals and can be put on in rather thick coating.
