Advertise
Here
Search 🔍
the Site
Problem? Solution? Chime right in!
(perhaps the world's last 'no registration' site)
"What causes unsatisfactory copper coating on a steel wire rod?"
I'm a student attached to industry, currently work to find out what has caused the unsatisfactory copper coating problem on a steel wire rod. the appearance of the wire rod is pale thus affecting its quality. (The wire rod is drawn from 5.5 mm to 1.0 mm)
Beryl Victoria Chua
Student - Malaysia
Plating is a complex process, Beryl, Would you expect to be able to write to a doctor and tell him/her only that you were pale and be told what the problem is?
Is the thickness up to spec? Is the color saturation a part of the quality specification, in that you say it's pale "thus" there is a quality problem, or is there an additional quality problem? If so, what is that problem? Is the copper plating bath a fluoborate type or what? Unfortunately, you are a long way from being able to get help on this problem at this rate. Good luck with it though.
Q, A, or Comment on THIS thread SEARCH for Threads about ... My Topic Not Found: Start NEW Thread
Consult'g, Train'g
About/Contact    -    Privacy Policy    -    ©1995-2021 finishing.com, Pine Beach, New Jersey, USA
