Prep of brass, silver, and copper before lacquering
After buffing with rouge and or brown tripoli buffing compound on eBay or Amazon [affil link] , most small shops I have seen use lacquer thinner on eBay or Amazon [affil link] Flammable! to hand wash parts before painting. Would like a safe solution.
Walter Poley
- Jacksonville., Florida
Hi, Walter. I'm not sure what you are implying. That lacquer thinner on eBay or Amazon [affil link] Flammable! is a dangerous material? (Yes, it's somewhat flammable). Or that the operation is too labor intensive? Or that the workers are jeopardized by skin contact with lacquer thinner on eBay or Amazon [affil link] Flammable! ?
The better way to clean brass and copper parts with lower labor, non-flammable solvents, and a much cleaner surface is via vapor degreasing. But this elegant solution has fallen into environmental disfavor due to the possibility of smog generation and/or chemicals that attack the ozone layer if the system is poorly managed. It's not an impossible situation though. Good luck!
February 19, 2009
