Expectations of Electroless Nickel.
Hello people.
Is two to three hundred hours NSS resistance a reasonable expectation for an electroless nickel coating if:
At this point, we are getting 5% corrosion within 24 hrs, which leads to intolerable corrosion by 48 or at best 72 hours. If electroless nickel cannot do this, can anyone suggest a coating which has a similar uniformity to e'less Ni, can get over 200 hours NSS, and preferably does protect sacrificially?
this is not easy: I'm a little stumped.
thanks in advance, Terry Roberts
terry roberts
- Australia
I would have expected a little more resistance from your EN, but EN does have pores in it and until you get to 0.0015" (1 1/2 mils) you will have attack thru the pores. Increase your thickness by 50% and your problem should go away.
Terry, Been there - done that. The answer to all your questions is YES. But add the following: a) you are using a 12% + phosphorous bath b) you are using a 3% solution of chromic acid as a final rinse Ray
ray delorey
- cambridge, ontario, canada
