-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 3158
Cold sealing of aluminum: crystals forming on tank walls
We have been using cold sealing for our anodised and coloured aluminum extrusions for the past 1 year and it seems to work fine with some occasional hiccups now and then. However of late we have some deposits of clear crystals forming on the sides of the sealing tanks. This crystals were also found at the bottom of the tanks as well. We fear that we may be overdosing our chemicals which may affect the sealing quality. Does anyone knows what could be the cause of this problem. Best Regards Elango
elango govin
Kemtec Sdn Bhd - Kuala Lumpur, Malaysia
Cold/Low Temp seals tend to crystallize more so than mid/high temp seals. Its just a function of the seal from what I have read and been told by several companies that supply anodizing seals. The only way to determine if its having a degrading effect on your anodized parts is to do a test on a finished part. We use a specific dye for this purpose, its purple in tone and you either pour or immerse the part in it. You can then tell if the seal is not functioning properly by seeing if the purple tone remains on the part. If there is no residue on the part after immersion, you should be fine. Contact the supplier of your seal and ask them to perform this test or if they have a kit that you can do likewise with.
Matthew Stiltner
plating company - Toledo, Ohio
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
