A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
(current
topics)
topic 3130
stripping off old zinc phosphate crystals
(1999)
My outdoor metal product is hot dip galvanized, then zinc phosphated, then epoxy primed, then polyurethane topcoated. Due to a production imbalance, I let the zinc phosphated items sit outside, and now I find they have what appears to be white rust on some of the surface. I do not want to prime them until I repair this "degraded" zinc phosphate surface. What I would like to do is strip off the old zinc phosphate and start over with new zinc phosphate without damaging the underlying zinc surface. I can mechanically strip it off, but that would be laborious and difficult. Is there a chemical stripping compound/solution which I could use to dip my object into and which would strip off the old zinc phosphate?
John Hobbs
- San Diego, California
(1999)
My tip for you is a trick. You have to prepare solution consist of the following:
Ammonium Hydroxide 37% solution (Technical concentrate).
Sodium Dichromate 10 grams per litre (To the concentrated Ammonium Solution)
Yours Sincerely
yehuda blau
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
(1999)
Clean, such as detergent bath and reparkerize. Try one piece before doing whole batch. Salt air, pollutants, or zinc phosphate will leach too.
Paul Podhorn
- Godfrey, Illinois, USA
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
