-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 2968
Electroless copper bath stability questions
Dear sirs, I study Chemistry in the university of Athens, Greece, and I plea for your help. I am working on plating ABS plastic and I need help upon the topic of the electroless copper bath stability. I use CuSO4, Rochelle salt, HCHO, NaOH. I am aware of many additives and chelate agents and the way they suppose to work. I have tried some of them. I use the bath at a pH over 10.5 I use air agitation. I found difficulty to use the bath after inactive periods.I need to know how to stabilize the bath as to be able to use it again, after periods of resting. I know that I must replenish. the bath, that I should filtrate it. What are the addit. that you propose me to use? What shall I do to the bath during its rest.? Shall I reduce the pH, and what I should do to reborn it after that, what to add? Shall I use air agitation through the resting periods? If I use an oxidizing agent (e.g. 2 mercaptobenzothiazole) as stabilizer, shall I also need to reduce the pH? I've also find the:".....during inactive periods store bath at 80% or less of make up...", while looking at a patent. Could you explain to me the phrase? I don't understand the phrasal verb. At 80% or less of what? Anyway, any extra advice would be helpful. Thank you Very Much. sincerely, Andrew Kourvetaris University of Athens Greece THANK YOU
Andrew Kourvetaris
- greece
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
