Summary for non cyanide copper plating Discussion
Non cyanide copper plating for ornamental 14 ga mild steel is possible, but the thread warns that standard acid copper baths such as copper sulfate or copper fluoborate cannot be applied directly to steel because they will not adhere. The main practical alternatives suggested are proprietary copper pyrophosphate baths, which several suppliers offer, though they are described as more finicky than cyanide baths. The answer also notes that it is not certain these non-cyanide systems will discolor with heat in the same way as cyanide copper, so testing would be needed if darkening, aging, or antiquing effects are important. Another option is to nickel plate first and then apply acid copper, but again the resulting color-change behavior would need to be verified. The discussion focuses on keeping the process simpler and more environmentally friendly while preserving the decorative finish.
Q. I visited a job shop that makes ornamental parts. You have seen them – the little garden animals and things like lizards and kokopelli’s, etc. They currently use copper plating and then coat with a clear coat to preserve. I wonder if a non-cyanide process for plating 14 ga mild steel and then clear coating would work – do you see any problems? What other treatments can be applied to the plated parts to impart color changes such as darkening, aging and various antiquing finishes? Trying to stay environmental friendly from a simplicity in process and regulation perspective.
John Moritz
equipment sales – Vancouver, Washington, USA
A. The typical acid copper baths (copper sulphate
Amazon [affil link] or copper fluoborate) cannot be applied directly to steel because they won’t adhere, for reasons more complicated that you probably are interested in hearing in the first round. There are proprietary copper pyrophosphate baths available from several suppliers; these are a bit more finicky than cyanide baths, and I can’t guarantee they will discolor with heat in the same way, but they are worth investigating.
Another alternative is to nickel plate first, then acid copper plate. Again, whether this will discolor the same way as their cyanide copper would need to be determined.
A. There are lacquers from companies like Agate that have some fantastic metal like colors without the evils of plating. Check with them for the level of UV stabilization that the have/need. You might also acquire the book on patinas in the book section at this site. Not that bad priced and lots of pictures. Sort of a minimum library for an artist.
– Navarre, Florida
Q. I am trying to electroplate mild steel with copper for an art project. I managed to get a little of the copper to plate but it seems that the dark “coating” on the steel prevents the copper from bonding easily and it just wipes off.
Is there a way to purchase sheets of steel, up to 16 x 20 inches, that does not have this “coating”? Is there a way, other than grinding, to get it off?
Lawrence Diggs
– Roslyn, South Dakota, USA
January 11, 2013
A. I think that when you say dark coating, you are referring to the mill scale on the steel. You can avoid this by buying cold rolled steel rather than hot rolled steel. Alternatively, you can remove the scale by sand blasting, grinding or with a solution of sodium bisulphide and water. You will find this acid salt sold as a pool additive (lowers PH.)
Justin Kumph
– Philadelphia, Pennsylvania
January 27, 2013
