Summary for powdercoating plastics Discussion
Powdercoating plastics is possible, according to the reply in this thread, but only with special materials. Lionel M. asked whether injection-molded plastic products can really be powdercoated and whether that requires special plastics or powders. The answerer says the information is correct and notes that in Europe injection-moulded plastic parts are powdercoated, but they are made from a special modified PA6 or PA 6.6 rather than ordinary plastics. These coated parts are used in applications such as connection parts, hinges, shower cabins, and suspension components for design radiators. The response does not mention any special powder formulation, focusing instead on the need for the right plastic substrate. Overall, the thread suggests that powdercoating plastics is feasible, but only for selected engineered plastics designed for the process.
Our company powdercoats large quantities of zinc based diecast door and window hardware. We also manufacture injection molded plastic products, which we hear can be powdercoated. Is this true? If so, are we talking about special plastics or powders? I would welcome any input.
Lionel M [surname deleted for privacy by Editor]
– Brisbane, Queensland, Australia
Your information is correct. Here in Europe injection moulded plastic parts are powdercoated. These parts are made of a special modified PA6 or PA 6.6 Parts are used as connection parts or hinges, etc. in for example shower cabins, suspensions of design radiators, etc. Best regards,
Remmelt Bosklopper
– Enschede, The Netherlands
We have done plastics which are a special grade and used for skis. I do not know the nature of your mould and unless I know further I cannot say for sure whether they can be done. For die cast we have special outgassing powders, which you are welcome to try. I could arrange to send a free sample on freight collect basis Regards R. Puru
Ramoo Puru
Singapore
Not only am I interested in powdercoating plastics but also fiberglass panels (FRP)
– Bendigo. victoria australia
Q. Dear Sirs,
I am interested in the powdercoating of plastics, particularly PVC window frames.
Does the PVC also need a special composition to make electrostatic spraying possible? or is a special pre-treatment necessary?
Do you know powder and equipment producers who have expertise in this subject?
Kind regards
Ben van Leeuwen
– Berlicum, The Netherlands
