No registration or passwords; no pop-up ads -- just aloha, fun, & answers.
(as an eBay Partner & Amazon Affiliate earns from qualifying purchases).
Advertise
pub  Where the
Q&As since 1989
Treatment of electroplating waste
Q. I am a postgraduate student of Water and Environmental Engineering at the University of Surrey. I have an assignment on the treatment of Electroplating wastes especially non-cyanide zinc plating waste and chrome waste and the subsequent recovery. I visited a plant at Slough and found that they are treating their waste by precipitating according to the waste i.e. they use sodium bisulphite if the waste is too acidic.Then after primary sedimentation they pass the water through a sand filter and then they discharge it.
I would like to know if there are any other cost effective and optimized systems ...i need to make a presentation , so I would appreciate if you could help me out with this
Anusha s [last name deleted for privacy by Editor]
univ of surrey - England
A. Anusha:
Some good books available on the treatment of electroplating waste include: "Operation and Maintenance of Surface Finishing Wastewater Treatment Systems" [adv: this book on eBay, Amazon, or AbeBooks] and "Water and Waste Control for the Plating Shop" [adv: this book on eBay, Amazon, AbeBooks]. For a much briefer treatment of the subject, there is coverage in the Metal Finishing Guidebook, the "Products Finishing" Directory, and the Electroplating Engineering Handbook [on AbeBooks or eBay or Amazon] .
I'm glad that you actually had a chance to see a plating shop--that's vitally important--but I think you still need to do some studying. I believe that the sodium bisulphite was used to reduce the hexavalent chromium in the waste stream to trivalent, in preparation for precipitation.
Removal of Copper from Electroplating Waste
Hi,
I am a student from Singapore Polytechnic and is currently doing a final year school project on "Removal of copper from electroplating wastewater".
However, my group members and I found that the presence of gluconate in the wastewater affect the efficiency of copper removal.
Hence, the following are some questions which we would like to ask you:
1) The chemistry of gluconate.
2) Is EDTA able to chelate Cu and separate it from gluconate?
3) Are there any chemical means of reducing gluconate.
4) Physical separation methods besides electrodialysis.
5) In your letter 3907, you mentioned that gluconate complexes with iron when ferric chloride [on eBay or Amazon] is added. So will gluconate complex better with iron or Cu.
Your help is invaluable to our project.
Thank you --From ChuChu, Sylvia, Jade.
ChuChu Leo
A. Gluconate is a wonderful chelator of many metals. That is why it's used in many alkaline tanks. EDTA is a stronger chelator, so that is no help to your problem.
To the best of my knowledge, most anything that you add to bust the gluconate will cause you other problems, with a net negative cost effect.
Keep the gluconate-bearing rinses/dumps away from the copper-bearing rinses/dumps is probably the most cost effective, even though it requires a second treatment line, or at least separate storage tank and the trouble of shutting down the other treatment to do the copper treatment. This could be cost effective by easier treatment of the other rinses.
A. Hi. I think James is right that keeping the copper and the gluconate separated is the best strategy if possible. However, if not possible, one potential treatment strategy is bringing the pH of the waste low, then adding an iron salt to try to get the gluconate to mostly tie up iron rather than copper, then raising the pH with lime. This strategy is sometimes called "chelate breaking" in the wastewater treatment industry.
Q. Dear Mr. Mooney,
I am studying at Ege University, Chemical Engineering Department and I am a last grade student.My diploma project is about "Treatment of Electroplating Industry Wastewater Treatment". I could not find sufficient literature information yet and I want you to inform me about this subject, please. I exactly want some information about which contaminants are included in electroplating industry wastewaters and which treatment technologies are applied ? I am looking forward to hearing from you soon.
With best regards...
KEMAL T [last name deleted for privacy by Editor]
Ege University, Chemical Enginering Department - Ýzmir, Turkey
A. If at all possible, visit a plating shop, Kemal, so you have a real feel for what you will be expounding on.
I've recommended 5 books, and I don't know what information you need for your chemical engineering diploma project that wasn't found in them. But you can search the USA's EPA sites starting at www.epa.gov for hundreds of duplicative reports on the subject. Best of luck.
Q. First I want to thank you for your time. My major is chemistry and now I'm doing a research about metal. My research is separation of transition metal from electroplating waste using a complex (diethydithiocarbamate or dithizone) and the analysis is using spectrophotometry (methods). And I need your help to find a procedure about the separation of the metal but not using precipitation methods. But if you have another procedure for electroplating waste it would be very helpful.
Viktor
student - Bandung, West Java, Indonesia
A. Hi Victor. Ion exchange or electrolytic recovery are two possible methods, although I'm not quite sure if that's what you're asking. Certainly with the right potential applied you could electroplate one out of the solution almost exclusively, leaving the other in solution. This is done for electrowinning or electropurification. Good luck.
Q. What is the mechanism of removal of chromium, and what are the effects of chromium, nickel, zinc, lead on animals & plants.
Tejpal [returning]
Student - Gurgaon, India
thumbs up sign Hi Tejpal. Yes, although any of those five would be a good subject for a thesis (or a report if you are a younger student), best might be to combine the first & second because a discussion of how you can do something together with why you would want to do it could make for an interesting topic. Good luck.
Q. Hello, I am a student from Poland I write an engineering paper on "Selected methods of electroplating wastewater treatment" needs some materials on this subject hard to obtain from national publications, therefore I am asking you to help me in this field?
Dawid Bujak
- Czestochowa, Poland
February 6, 2018
Q. Hello
I need material for engineering work on the topic of "methods of purifying galvanic sewage" (what are the methods, description of these methods) if someone has such materials or knows where to look (articles, publications, etc.), I would be grateful for any help.
Dawid Bujak [returning]
- czestochowa, POLAND
February 10, 2018
Usually available on eBay; sometimes
(affil links) mfg_online
A. Hi Dawid. We've listed a number of books which your university library should be able to obtain, and Metal Finishing Information Services could do a lit search of published articles for you if the project can afford it (surfacequery.com), while scholar.google.com and books.google.com should find some on-line stuff. Meanwhile, though, you can download the Metal Finishing Guidebook which has several good chapters on the subject.
Because technical libraries have whole shelves if not whole aisles on the subject, you obviously must very quickly choose a more narrow thesis for development: waste reduction in one limited area, applicability of RO towards ..., applicability of DI towards ..., recovery of metal values from ... plating sludges, etc. Good luck.
pic of Ted Mooney
February 2018
Q. Thank you.
I will try to find something but it is harder if I do not know what to look for. I mean specifically about these methods: what are the most popular or the precipitation method is not a very general name. With this I have the biggest problem to find a few "popular methods" as their name, to get information about them. You could give some, in your opinion, interesting and popular methods of electroplating waste water treatment. I need two or three methods.
February 11, 2018
A. Hi David. The Metal Finishing Guidebook, already suggested, is available to you instantly on line and for free. It has a chapter titled "Wastewater Treatment" with a subheading 'Conventional Method of Wastewater Treatment'.
That chapter is immediately followed by a "Waste Minimization and Recovery Technologies" chapter with subheadings including 'Evaporation', 'Reverse Osmosis', 'Ion Exchange' 'Electrodialysis', and others. If you will take yes for an answer and quickly skim those 2 chapters you'll have outstanding insight into your whole project. Good luck.
pic of Ted Mooney
February 2018
Dawid
Try nmfrc.org for some wastewater treatments.
Willie Alexander's
February 13, 2018
Disposing of plating solutions / closing down electroplating shop
Q. We will be closing down our electroplating shop over the next few months. Our tanks are all 100 gallons. We have copper, brass and silver cyanide, non cyanide zinc, acid copper and watts nickel. What is the most effective way to dispose of the contents of each of those tanks?
Steve Pearce
- Summerland, British Columbia, Canada
July 24, 2018
A. Hi Steve. If you can find someone to buy those solutions for $1 each, so they are not waste products that would be best.
There might be a different permit process or effluent standards for closing down a plating shop in BC than for running one; I don't know. But if I were you I would keep very careful logs of exactly what happened to the contents of each tank.
Conventional 'chemical destruct' (including alkaline chlorination of cyanide) should work. Do not mix anything with anything first though; treat each tank separately. If you don't know how to do it, or what is legal and what isn't, you can probably retain a cleanup specialist to haul the contents away or do the treatment on site. Good luck.
pic of Ted Mooney
July 2018
Consult'g, Train'g
