Summary for black chromate zinc magnesium Discussion
Black chromate zinc contact with magnesium is discussed as a corrosion question, but the answer given is cautious: John notes that the outcome depends heavily on the environment and the exact part conditions. He asks whether the assembly is in a moist city or marine setting, whether the magnesium is treated, and whether the parts rub together, saying those details are needed before predicting galvanic corrosion. He does not identify any special “weird effect” from the silver in the black chromate itself, and instead recommends gathering more information about the application before drawing conclusions. Mike McDonald replies that he is looking for real-world experience with black chromate against magnesium and is trying to obtain magnesium for his own salt-spray testing. The thread ends without a definitive test result, so the practical takeaway is that corrosion risk cannot be judged from the finish alone.
Q. I would like to know if Black Chromate over zinc plated steel stands up well while in contact with magnesium, or if some type of galvanic corrosion occurs, perhaps due to the silver in the black in contact with the magnesium.
Mike McDonald
– Jefferson, Wisconsin
A. Dear Mike,
An awful lot depends on the environment in which the “couple” is placed, is it a moist city environment?, is it a moist marine environment?, is the Magnesium treated in any way?, do the parts rub together?
Describe the part & its use better .
Put together as much information about the part & its use and we can probably give you a fairly good estimate of what to expect in terms of corrosion , but without some environmental input, I am not prepared to “jump in the deep end”
regards
John Tenison – Woods
– Victoria Australia
Hi John,
Thanks for responding. What I was wondering was if anyone had experience with Black Chromate in contact with Magnesium, and if so was there any weird effect from the silver to magnesium contact. In the meantime I have been attempting to get some magnesium so I can run tests on my own in salt spray.
Thanks again,
Mike McDonald [returning]
