A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
Here
FORUM
(current
topics)
topic 2584
Copper Analysis
(1999)
I am wondering if any of you can give me information on a method for determining copper in our nitric acid based deoxidizer. The range I'm looking at is in the ppm usually between 50 and 500. Our deox. also contains ferric sulfate, a small amount of fluoride, a lot of zinc; I'm not sure if these are an analytical problem or not. I would like to find some type of wet-test that can give me a fairly accurate result while, hopefully, avoiding the use of highly toxic reagents. I'm fairly new to the field, therefore I don't have a vast pool of knowledge nor the means to obtain a lot of expensive gadgets. Titration would be my preferred method. Anything you can share will be of use.
Thanks for your time,
James
James A. Corier
(1999)
James,
In your case, I believe AA analysis is the most reliable and accurate method for determine the copper content in the ppm range.
Ling
Ling Hao
- Grand Rapids, Michigan
(1999)
Hi James,
I tend to agree with Ling on this. AA analysis would be your most reliable method of CU detection. If you don't have access to an Atomic Absorption Unit, perhaps you could send your samples to aan outside Lab. Chemet Kits and the like are just not that accurate.
Kitt
Kitt Daly
- Austin, Texas
(2001)
Hello,
I am trying to determine copper dissolved in transformer oil. I would like if you can recommend a method. I think atom absorption would be suitable, but I am not sure about analysing oil in the aapparatus. May be I should use a solvent. In that case which one? Must I extrat before analysing or it is OK to inject oil/solven in the atom absorptoins apparatus.
El Sayed Badawi
- Stockholm, Sweden
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
