A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 2457
High voltage electropolishing process
(1998)
Whether are known to You a method and solutions for polishing various metals and alloys? In difference from a method of electrochemical polishing this process can take place at voltage, more than 200 v. Between a surface of an item, which is immersed in a solution, and the electrolyte forms an interval consisting of a vapour. In this interval there are electrical discharges. Under operation of discharges and active ions there is polishing a surface.
As electrolytes use water solutions of salts at concentration from 1 up to 5 %%.Value pH from 5 up to 8. The metal, which is remote from a surface, is transformed into a hydrooxide both is besieged and can be separated very simply. There are no dangerous and harmful scraps in atmosphere and system of the water drain. High efficiency of process.
Disadvantages. Higher consumption of electrical energy in comparison with conventional electrochemical polishing.
Hennadzy V. Mosalev
Smorgon, republic of Belarus.
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
