HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
Live! From beautiful Pine Beach New Jersey: Welcome to the world's most popular metal finishing website
14173, p2
Painting a plastic (polyethylene) motorcycle gas tank?
1     2
Q. Okay, I am also looking for an answer to this question - BUT - I own an old Armstrong/CCM with a plastic tank - that the previous owner had successfully painted pure white, 3 years ago, and still looks like new - so... it IS definitely possible.
John C [last name deleted for privacy by Editor]
- Bridgwater, Somerset, UK
Krylon Fusion
A. Hello! I would suggest if you don't have to paint plastic, don't paint them! They will look nice at first then after awhile you will be wondering how do you take it off (soak them in brake fluid over night, works like a charm) Especially plastic tanks. You will find your tank will start to sweat and eventually crack! From previous experience! If it has heavy oxidation on it, take the time to razor blade it, scrape it off. It is time consuming but you will be more that happy with the results in the end! Then sand them down with medium-fine Sandpaper [linked by editor to product info at Rockler] and work keep using finer sandpaper. Then use a hard plastic conditioner on them. They will shine like the day they were on the showroom floor! Take care guys.
Korey L [last name deleted for privacy by Editor]
- Canada
thumbs up signMy husband and his friend is going to try painting my bike will let you know how it went. I have an old '82 Honda Goldwing.
Lori W [last name deleted for privacy by Editor]
- Chariton, Iowa
A. Last week I followed advice of using the Krylon paint, my husband painted my motorcycle, which was sun faded black, with black Krylon paint and misted over that with a car paint that has metal specs. I have a '82 GL1100 Goldwing the outer tank and fenders are plastic, so far so good, it's just been about a week and we haven't buffed it yet though. Will reply again if problems arise.
- Chariton, Iowa
A. Painting my gas tank on my cr500 motocrosser was a pain, like most of you here it peeled of about a week after application, simply due to the vapours permeating through the walls and causing it to bubble. Only way I could find was to use fibreglass resin (mixed with pigment colour of your choice, black in my case) with a couple of coats and a good sanding/polish it looks lovely (and solid so it won't bubble).
Simon T [last name deleted for privacy by Editor]
- Cambridge, England
Q. I have tried using the Krylon Fusion on a dirt bike fuel tank but it peeled off. I'm guessing there needs to be some surface prep to get the proper adhesion. I'd also like to spray all the plastics (fenders and side panels) and am curious about flex cracks. One email said to use a flexible primer like used on automotive bumpers. I would like someone to clear up the confusion and misinformation and provide a known workable solution! Thanks!
John W [last name deleted for privacy by Editor]
hobbyist - Dillsburg, Pennsylvania
Ed. note: Hi, John. We see no 'misinformation'. Several people told us what they tried and that it didn't work. Others said you might get paint to stick if you are willing to do the difficult mechanical prep, followed by flame prep, followed by dyne testing that they detailed. Others proposed the compromise of switching to bed lining material or resin instead of paint.
There are thousands of different plastics, and Krylon Fusion works fine on some in some applications, and not on others in other applications. Similarly, some forums recommendBulldog Tie Coat [linked by editor to product info at Amazon] for plastic bumpers. But plastic gas tanks are a different material than plastic bumpers, and a completely different application. A simple method to guarantee adhesion of paint to all plastics under all conditions without flame prep, dyne testing, and other complications simply doesn't exist, sorry. Good luck :-)
A. I have a 1988 Yamaha YZ 125 dirt bike with a factory finish on the plastic fenders that peeled off. I bought two new plastic fenders at the dealer and used 'plasti-coat' brand spray paint. This paint is just designed for touch up work, but it has worked wonders on the new fenders. I began by applying a VERY light mist of color to the surface, let it dry for up to 10 minutes and repeated up to seven coats. No problems yet and a great glossy finish.
Jamie C [last name deleted for privacy by Editor]
- North Hampton, New Hampshire
Q. Just like everyone else I want to paint my Plastic fender, side panels, etc, they are white, I would like them navy blue or black, I think I'm going to try that Krylon paint, If it works it will look sharp, my gas tank isn't plastic though, hmm.. I can probably find something to work on that, what about the seat? haha, It's a ugly light blue color, probably best to just leave it, but I would like it black, maybe I can find one for not too much money or I can find a cover for it... I'll post a pic in a month or 2 when It's looking good.
btw it's a DR125SE
if for some reason I shouldn't do what I just stated, I'm bookmarking this site so POST quick so I don't make a fool of myself...
Jake Burns
- Maine
A. I ran into the same issues that most of you have described in regards to painting plastic. I have tried every technique. Bulldog does not work well on PE. however, I have finally found a method that works really well but its a bit expensive. I used PPG products; started by cleaning and degreasing all plastic then lightly sanding with 240 grit then 400. The plastic was then cleaned with soap and water. I then applied 2 light coats of PPG plastic adhesion promoter ($45). Waited about and hour then applied 4-5 coats of PPG flat black automotive paint ($50). It only takes about 10 minutes to dry so applying 5 coats takes about an hour. Let is dry for 24 hours then sand lightly with 400 grit and apply final PPG clear coat ($50) which gives a little shine and a strong hard finish. It looks really good and hasn't peeled off. The only problem is that your going to spend about a $150. The paints come in quarts and you only need about 1/5 of it to do all the plastic.
Good luck
Cardounel
- Columbus, Ohio
A. I've got an old Honda 200xr. I think that heating the plastic with a gas flame or heat gun does restore the color. I just tried a little test piece on my tank. One must be very careful not to get the temperature too high and the tank has to be empty as well.
Richard Redecker
- windhoek, Namibia
A. The Only Answer To A Faded Plastic Tank Is NOT To Spray It, But To Give It It's Original Colour Back!
I Also Considered Spray, But The Bubbles "O" No!
Buy Yourself Or If You Have At Home A Bottle Of Brasso [linked by editor to product info at Amazon], You Know the Thing You Clean Copper With! Yes! With A Sponge And Give That Tank Some Elbow Grease!
Believe Me It Works!
Morne Wentzel
- South Africa
January 8, 2008
A. PAINTING POLYETHYLENE OR PROPYLENE GAS TANKS AND MOTORCYCLE PARTS "DOES NOT WORK" WHAT I DID WAS:
1. Sanding PE or PP really just moves the surface area (fibres) of the plastic around, this is what we want, cause we're not trying to really remove material, but surface condition it! What we want is kinda like a "fur" texture after sanding, and to achieve this start with a 60 or 80 grit cloth backed quality sandpaper. I like wet dry stuff myself. Ya have to do it by hand, electric sanders don't work cause they are too fast and melt it. So go ahead and sand the hell out of it, then move to next grit, maybe 100, then 120, stop at 220. Should have that white "fur" texture.
2. Run down to local tool store and grab a torch or a heat gun (safest) cheap ass heat gun cost $24.95 (ask the clerk to plug it in first, pretty cheap china one)
3. Keeping a distance,start at bottom of tank (course empty if first and allow fuel to flash) where you can't see it. This is the "practice area", now heat that fur! ever so gently,and wow, a new tank.
4. Buff with "Brasso copper polish". Acrylic bathtub polish works good too!
enjoy.........
Don Healey
- Kelowna, BC, Canada
March 10, 2008
Q. How to prep paint and gloss plastic 2006 yzf r6. I'm getting a custom air brush job on my Yamaha r6 and I was wondering if anyone could give me some directions.
Justin Evans
- Raymore, Missouri
April 28, 2008
A. The trick for painting PE Gas tanks seems to be:
- Removing all the gas, cleaning the inside, and leaving the tank out well ventilated in the sun for about 2 weeks, so most of the fumes trapped in the plastic can leave the material.
- The putting slow hardening "440" Epoxy on the *Inside*, moving the tank around for about an hour to get a nice thick layer, and then letting the rest drip out.
- Letting the epoxy harden out for about 2 days, also well ventilated.
- Then painting it with car-bumper paint, which is rather flexible and sticks to plastic.
Kind Regards
*Anna.
Anna McMillan
- Netherlands
November 17, 2008
thumbs up signI have an 87 cr80r and I have had the plastics painted for about 2 months with Krylon Fusion [linked by editor to product info at Amazon] . I have painted the gas tank, fenders, and number plates. they haven't bubbled yet.
Terry Morrison
- Peebles, Ohio
March 30, 2009
A. It doesn't work to paint dirtbike plastics. I have tried it, and the paint is fragile and scrapes off easily, cracks and paint on the gas tank bubbles and peels off. The best solution is to buy Plastic Renew [linked by editor to product info at Amazon]. You can get it from your local shop or a site like denniskirk.com. You basically sand the plastics with different grades of wet sandpaper until you sand off the yellowing and discoloration, then apply the plastic renew. I wasn't sure if it would work, but I have used it on three bikes and a four-wheeler now with very impressive results. It really made things look nice. White plastic works the best, and black is the hardest, but all colors work.
Adam Timmins
- Logan, Utah
September 28, 2010
A. Found this product out of S. Africa and Australia:
Seems it is a breakthrough, but why not in USA? : flowkochem.com/FF_Polyethylene_PrSheet_fin.pdf
Mike Lerner
- Bakersfield, California USA
September 28, 2010
Hi, Mike.
Thanks. But these vendors try to keep their proprietary systems secret, offering no reference to even what general technology is involved. So how can anybody say whether it's a breakthrough or just the same-old same-old as Krylon Fusion, or Bulldog Tiecoat, or Plastic Renew? But the other three seem aimed at the end consumer whereas the flowkochem products seem to be aimed at auto manufacturers. Thanks again.
Teds signature
finishing.com
Pine Beach, New Jersey
Striving to live "Aloha"
November 25, 2010
A. # Wash tank with a good cleaner, like Castrol Super-Clean, both inside and out. I use a scouring pad (like Scotch-Brite brand) to really rough up the pores, using the cleaner and rinse out well with water. It is advisable to use rubber gloves, as this cleaner sure can dry out your hands. If there is varnished old fuel in the tank, an automotive grade acrylic lacquer thinner or Acetone should be pored inside the tank to loosen up the deposits. I shake the tank vigorously then empty the solvent into a plastic container.
# Now wash the outside of the tank with acrylic lacquer thinner or Acetone. I use a parts brush in a large plastic container. What was left over from the above procedure should work fine. This is to remove most of the old decals and adhesives, as well as any remaining grease or grime in the plastic pores.
# The tank should now be flushed with soapy water, both inside and out, and repeatedly rinsed with clean water.
# It is now time to sand the tank. I use an orbital auto body sander (dual action or DA sander) and start with 80 grit on the deep scratches and gouges, if there are any, as well as to remove old decals. I then take 180 or 220 grit on the sander and do the rest of the tank, as well as the areas that were sanded with the 80 grit, in an effort to minimize the scratches. Try to keep the sander flat at all times.
# A scouring pad is then used on all the edges, the undersides, and any areas missed by the sander, to promote adhesion for the top coating process.
# The tank should now be blown off with compressed air. Then washed again, both inside and out, with soap and water and thoroughly rinsed. Allow to air dry completely.
# Wipe the tank down with automotive grade wax and grease remover and use a tack cloth (automotive grade) to remove dust particles. The tank should now be ready for top coating.
# A product that I highly recommend for promoting good adhesion to plastic parts and personally know works very well is Sherwin Williams # UPO7227 Adhesion Promoter. This is available in aerosol spray cans as well as quart cans. The adhesion promoter should now be applied. I apply 1-2 wet coats, and let dry for about 30 minutes. I was able to do 4 tanks with one 16 oz. aerosol can.
# You are now ready for the priming process. I used a flexible primer manufactured by SEM. It is available in quarts and possibly aerosol. The SEM part number is 39134 and it is called Flexible Primer/Surfacer. This is a great product and builds nicely. It can be sanded after 45 minutes. I apply at least 2 heavy coats, let dry, then wet-sand using 220 grit wet/dry sandpaper.
# The tank should now be thoroughly rinsed and dried. Apply another 1-2 good coats of SEM # 39134 Flex-Primer. Let it setup (dry) then wet sand using 400 grit sandpaper. Thoroughly rinse again, and assess your work. It is possible that the tank may need another application. If so, repeat as necessary, final sanding with 400 wet. When finished, rinse the tank again thoroughly, both inside and out, and let dry. On my original Can-Am MX-3 red fenders I had to perform the priming/filling process 3 times to remove all the scratches, as one of the fenders was really bad to begin with.
# You are now ready for top coating. Remove any oils from handling using wax and grease remover. Use sparingly as to not saturate the current layers you have finished thus far. Make sure the tank is completely dry. Now wipe using a tack cloth to remove dust.
# Any places on the tank where bare plastic is showing, where the SEM primer has been sanded through, should be covered lightly with the UPO7227 Adhesion Promoter. There is no need to cover the entire tank again with the adhesion promoter but it won't hurt if you do.
# Allow to dry. Tack dust again using tack cloth. Now the color is to be applied.
# I have always had good success using Sherwin Williams automotive finishes. I use Sherwin Williams acrylic enamel with hardener for most plastic. Now select the paint color of your choice.
# The Sherwin Williams acrylic enamel should be mixed as stated on the can, using 8 parts color, 4 parts reducer, and 1 part hardener or catalyst. The following additive should also be added: Sherwin Williams Multi-Flex, Flex Additive, # V6-V299. Two parts should be added to the mixed paint. Ensure you are using an OSHA approved paint mask, as the mixed paint contains volatile chemicals, including Poly-Isocyanides.
# I generally apply 3-4 good coats to ensure full coverage, obviously allowing the paint to flash between coats to minimize sags or runs.
# The paint should be allowed to dry completely. I generally wait 2-4 weeks, then apply the decals. The finished tank can be washed and waxed, and cared for like any automotive finish, but waxing should be done only after about 4 weeks time, so any remaining paint vapors are allowed to escape.
# The finish holds up incredibly well, as it is an automotive paint re-finishing system. There are sealers to seal the insides of these tanks, and they will work well for preventing the gas fumes from trying to escape through the plastic pores of the tank. When the fumes try to escape, from leaving the gas in the tank for prolonged periods of time, there is a bubbling problem that is created near the bottom of the tank. I have done many tanks in this manner, and the ones that have a good tank vent, and are drained and flushed with water after riding seem to last the longest. Those that leave gas in the tank without sealing the inside seem to bubble near the bottom. Those that seal the inside of the tank seem to last the best, and the finish on the tank is as durable as any finish on any automobile, as automotive refinish products were used to restore the plastic above.
Mike Garrett
- Brush Prairie, Washington, USA
April 20, 2011
A. I was told by a bike shop to have a tank cover made by an upholstery shop; they can make a cover any color and some with custom designs. These work good for plastic tanks as they won't hold paint.
Jeff Smith
- Salt Lake City, Utah, USA
June 25, 2011
A. Painting a cleaned and lightly sanded polythene gas tank with three coats of 'latex 2000' (water based latex solution), builds up a rubber undercoat that is flexible and allows a top coat of red oxide primer, followed by a gloss oil paint finish to be applied. It worked for me.
Chris Prus
- New York, New York USA
March 22, 2012
Q. Will fibreglass resin work to seal the inside of the tank?
remus vorster
- g/dal South Africa
SEM Adhesion Promoter
SEM Flexible Primer
April 29, 2012
A. Hello all,
I am pleased to report that have very successfully painted a plastic fuel tank on the dirt bike, used it for racing and many weeks later all is good.
Special materials:
Acetone [linked by editor to product info at Amazon]
fuel tank liner from Blue Lightning Products
adhesion promoter spray can from SEM =>
flexible primer from SEM =>
(zinc plating kit)
Procedure:
Thoroughly wash the tank inside and outside with acetone several times over several days, weekends to remove any trace of old fuel, grease etc
Removed rust and zinc plated the metal piece of the tank opening. Obviously this has a lot of sub-steps but not the point of this article.
Poured a pound of wood screws inside the tank, wrapped it in a blanket, and ran it for 30 min in a wash-drier. The intent is to roughen up the inside for the liner to grip well.
One more shot of acetone inside and leaving everything to dry thoroughly
Lined the inside of the tank as per method indicated on the can. This is a little strange as the liner takes a long time to dry. When left overnight, most of it sets at the lowest point and I wasn't sure there was any liner left on the other parts of the tank. So I did it twice over two week ends. The liner is a super thin and hard green layer.
Sanded the exterior of the tank
Cleaned again with acetone and thinner
Applied the adhesion promoter
Applied two layers of flexible primer
Flatted the primer obviously: that primer is super hard, incredible
Applied two layers of base coat
Applied two layers of clear coat
Got really very pleased with the result
All details and photos here:
http://www.xr500only.com/restauration-tips/how-to-paint-a-plastic-tank-and-use-it-normally
Eric Feron
- Sunnyvale, California, USA
November 22, 2014
A. Using a micro-porous paint should work -- they do them for wood, maybe that'd hold up on a plastic tank. My yz465 looks terrible, need a tank job.
brendan mahoney
- united kingdom
June 1, 2015
A. Rit dye worked great; did my dr350 about a year ago and it's still great, except for the little bit of tree damage.
Ken Greenwood
- Auckland New Zealand
October 31, 2015
A. To make paint bond to polyethylene you must flame treat it first.
gerard conti
- leominster Massachusetts
Painting HDPE Motocross gas tank
October 11, 2018
Q. I know that many people would love to be able to paint their old faded beat up MX fuel tank. I have never tried this, but have been told that this is not possible due to the out gassing of fumes thru the plastic "pores". This being said, does anyone know of some process that would allow for the successful application of a good Automotive paint finish that will not "bubble up" once applied to the HDPE tank. I would like to seal the inside of the tank with a good plastic epoxy gas tank sealer. My thinking is that this may solve the out gassing issue in order that the paint may stay adhered. First off do these epoxy gas tank sealers work? or will this peel or negatively effect the performance of the plastic tank? If this were successful in sealing the inside of the tank, what other special provisions are needed to successfully paint the exterior of the fuel tank. Does an adhesion promoter and flex agent need to be used with the paint for most durable long lasting finish. Would a special paint such as ("Imron" or "Emron", not sure how it is spelled) Aircraft quality paint improve the chances of obtaining the best finish. Has anyone ever tried this with Powder coating the exterior of the tank? Hope this will get a lot of response in order that there maybe a reasonable way to successfully paint your MX plastics without the negative consequences that we all have heard about or experienced. Thanks in advance for your knowledge and input on this matter. Sincerely, Kevin
Kevin Forman
VMX Enthusiast /restorer - Doylestown, Pennsylvania
1     2
If you have a question in mind which seems off topic, please Search the Site
ADD a Q, A, or Comment on THIS topic START an UNRELATED topicView CURRENT HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2019 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
