Q&As since 1989
Platinum Electroplating
I am looking for any information on electroplating platinum for microelectronic applications. The application requires a smooth deposit less than a micron thick.
Bob B [last name deleted for privacy by Editor]- Semitool
Hi Bob
I toured Semitool a few years back when you guys were developing the wafer-plating platform. What a great outfit you run up there. Platinum is electroplated from two different electrolytes. One is from an orange chloroplatinoic acid and the other is from a black sulfuric/nitric compound. Both are touchy and take a bit of experience to run routinely, as neither is inherently stable while operating. They are offered by Technic, Sel-Rex, etc. The single most important factor in Platinum plating is the substrate material & its preparation. Each of these baths "hate" various substrates. Nickel is the black bath's mortal enemy. Internal tensile stress in Platinum deposits can run extremely high, and in small devices, just a nick can cause a section of the deposit to spring-delaminate. But proper DOE can identify excellent operating parameters that will yield Pt that won't even orange-peel during 90 deg bend test. But again, the trick to working Pt is long-term process maintainability. It takes a lot of effort to keep it running in spec.
Dave
Dave Kinghorn
Chemical Engineer
SUNNYvale, California
How to get platinum coating on molybdenum metal
We wish to obtain a coating of platinum or Pt-Rh alloy on cylinders made of molybdenum metal. The parts will be exposed temperature of 1600 - 1650 degree C and will also come in contact with molten slags, fluxes and glasses. The components are to be used for measurement of high temperature viscosity of melts. Is it possible to have electrolytic deposition of platinum or Pt-Rh alloy, or deposition from some molten salt bath?
Somnath Basu2006
A. Hello, Somnath. Yes, platinum can be electroplated. Rhodium can be as well -- but I am not sure if a practical Pt-Rh alloy bath exists. Are you sure that platinized titanium would not fill your needs, as this is a well developed and rather commonplace material? Good luck.
Q. We have been using an acid (pH3) ammonium sulfamate bath with diamine platinum sulfamate complex for two years. It seems very temperamental to pH, weekend storage temperature, trace contamination and with all that I can't get it to last more than six months. Even with Barium treatments to drop out sulphate, which forms from the sulfamate hydrolyzing from elevated temperature and acidity at anodes.
Can anyone tell me how to make the complex last longer? It really makes a beautiful deposit when it wants to. The complex that drives the deposit is definitely not the advertised (NH4)2Pt sulfamate. It forms from this over time and under the right temp., pH, density and balance of sulphate. Does anyone have some experience they would like to share?
- Claymont, Delaware
October 12, 2010
