Rusted Cast Iron: Smart Finishing Options for Statues
Summary for rusted cast iron Discussion
rusted cast iron statues can be treated in different ways, but the thread does not confirm a reliable method for making the rust green. Stuart Hanford asked how to turn the rust on two large cast iron French garden statues green and inhibit future rust after the dealer disappeared. Nicholas Subryan only said he would like to know the answer too. Goran Budija suggested a blackening treatment instead: a spray or paint made from tannic acid, phosphoric acid, and water, applied to a thoroughly degreased object, then lacquered if desired. Ted Mooney, P.E. added that cast iron can simply be painted any color, implying a conventional paint system is the practical route. Overall, the discussion points more toward blackening or painting than a proven green-rust finish.
I purchased two cast iron French garden statues from a dealer. He promised to send info on how to turn the rust a green color and inhibit future rust but he has gone out of business with no forwarding address. Can anyone please help with any possible treatments for the statues? They are about 5′ high.
Stuart Hanford
– Lebanon, Pennsylvania, USA
Sorry I can’t help you but if you find the answer to your question I would love to know.
Nicholas Subryan
– Bridgetown
You can colour it black. Here is recipe!
20 gm tannic acid
15 gm phosphoric acid
1 lit. H2O
Spray or paint on thoroughly degreased object! Lacquer it if you want !
– Cerovski vrh Croatia
You can paint Cast iron in any color you like.
It is best to paint it with a paint called
Hammerite Rust Cap
[affil link]
since it can be used directly on rusted surface. You only need to brush the loose iron off.
You can also use two colors of lacquer to get an antique look on the surface.
First apply the darker color on all the surface and then spray the lighter color onto a cloth and apply the color with gentle strokes
(not to much)
Try using black and gold or Black and Bronze.
Thorsteinn Jonsson
– Keflavik, Iceland
Q. I have some 19th century containers made of cast iron. Now that the old paint and rust have been taken care of, and liking the look and color of the cast iron, I thought about using a transparent finish instead of re-painting. Since rust prevention usually includes a primer coat of paint followed by the finish coat paint layers… what about varnishing?
William O’Neill
surgeon. – Stavelot, Belgium
February 12, 2009
A. Hi William
If they’re indoors in a benign environment as decorations, varnish or other clearcoat should be okay. But such a finish will not hold up outdoors.
