A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 758
Electroforming of dies for molding electronic capacitors
(1998)
We are currently using machined dies for transfer molding of electronic capacitors. I recently heard these dies could be made by forming a mold of the desired shape and then the die is built up using a electroplating process.
Have you ever heard of a process like this
If so please steer me in the right direction. Thank you
Justin Dameron
(1997)
Justin:
Electroformed molds or mold inserts are quite common in the industry. If you are interested in finding out how your dies/molds can be electroformed, e-mail me a sketch of the mold or a DXF file.
Regards, Berl
berl stein
berl sig
"PlaterB" Berl Stein
NiCoForm, Inc.
Rochester, New York
nicoform
December 19, 2008
Hi, Justin. The general name for the process that you are speaking of is "electroforming". what this means is that the same process that is used for electroplating is used, except that the plated layer itself becomes an object, and whatever the plating was plated upon is removed (melted away if it wax, dissolved away in caustic soda if it was aluminum, physically stripped off, possibly for reuse, if it was stainless steel. Depending on the quantity required, additional electroforms can be generated from the first electroform.
To give a more concrete understanding of what we are speaking of, consider the manufacture of vinyl records. A lacquer master is cut, then a nickel electroform is made from it that can be used as a stamper or a number of "negative" electroforms can be made this original nickel electroform, and then dozens of stampers can be electroformed onto these "negatives".
You would be in the best of hands with Berl :-)
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
