A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
(current
topics)
topic 742
Anodes for Nickel Sulfamate electroforming
(1998)
I'm electroforming nickel from a sulfamate bath, and I understand that a sulfur-bearing anode is needed if no chloride is used in the bath. How much sulfur is enough for this purpose? Also, can anyone suggest a supplier that sells this type of anode? I'm looking for a small amount; the bath is only 2 liters.
Jim Rogers
microsystems engineering - LSU - Baton Rouge, Louisiana
This anode material is a standard product, Jim. Inco calls them "S-rounds"; I'm not sure what Falconbridge or others call them, but just ask for sulfurized nickel anodes. Sources include Tally Metal Products.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
(1997)
Anodes for 2 liters - I am not sure that INCO or any other big supplier of nickel will agree to sell you less then 50 KG. Try to buy nickel anodes for Hull cell or for Jiggle cell. Sara
sara michaeli
sara michaeli signature
Sara Michaeli
chemical process supplier
Tel-Aviv, Israel
sidebar (1998)
I give up, Sara -- what's a Jiggle cell?
Teds signature
finishing.com
(1998)
Jiggle cell is a one litre cell used with bent cathode. Gives you a better way to evaluate problems in plating solutions, like roughness,covering power etc. It has a few benefits over the regular Hull Cell. Sara
Sara Michaeli
Sara Michaeli signature
Sara Michaeli
Tel-Aviv, Israel
(1998)
There are many types of nickel anode material available.With reference to running in a chloride free bath (the main reason for this might be to lower the nickel deposits internal stress) The addition of sulfur and carbon to the anode material allow for higher plating rates, however they are not required for plating to take place up to approx. 20 ASF. So if you are starting out you can use what is available to you, but I do suggest the use of anode bags and titanium hooks, baskets or bolts should be used for electrical contact.
Anthony J. Covey
electroformer - Corona, California
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
