A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 730
Anodized surface for electrical insulation
(1998)
I'm interested in learning more about anodized aluminum, specifically whether it can reliably be used as an electrical insulator. As I understand the finish, it's primarily aluminum oxide (alumina ceramic) which is a common material for electrical isolation. I'm considering hard anodization, to resist abrasion. Is this a common practice, and to what voltage? Are there specific ways to call out the finish for this application? Any comments would be appreciated.
Charlie Amsden
(1998)
Anodize and hardcoat anodize are very good electrical insulators. Dielectric breakdown values greater than 2,000 volts have been reported for hard anodize. Of course, these are laboratory conditions. In practice, the coating quality and thickness, base aluminum alloy, surface finish, sealing method, racking technique, and part geometry all effect the insulating properties. We run a number of jobs in our shop where hardcoat anodize is specified primarily for electrical isolation. Wear and corrosion resistance are secondary benefits. In high performance applications, a two mil (50 um) coating thickness is usually specified. Grounding or part to part continuity can be achieved by masking off contact areas.
Chris Jurey, Past-President IHAA
Luke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
luke engineering banner
(2001)
Our facility produces oxide insulated aluminum conductors for the electromagnetic industry here in the U.S.. The concept is to produce anodized coils in continuous form that eliminates the need for any organic interleaving in the coils. Produced with a .0002" thick anodic coating, the coils used in separating equipment and sensors is capable of easily withstanding power inputs used in the magnetic industry.
Jason Von Marschner
- Pomona, California
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
