A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
(current
topics)
topic 705
Where can I find information on screw finishes?
(1996)
We join aluminum die castings with threaded fasteners. We try to use commonly available carbon steel screws. We have used zinc plated fasteners with great success, but the call outs all call for "...with yellow dichromate". How and/or where can I learn about screw finishes, dichromate, etc., so that I can make informed decisions in our search to reduce cost, insure effective corrosion protection, and save the environment?
John Scarborough
- Schlumberger
(1997)
John,
Carbon steel against aluminum will rust fairly fast.
Most if not all zinc plated screws are chromated after plating. Most use a clear chromate because it has more eye appeal. Yellow has significantly better salt spray corrosion resistance than clear. Olive drab is even better but is not generaly available as it is ugly.
Cadmium is less prone to cause corrosion of the aluminum than zinc is, and it can receive a similar chromate.
Since you are using carbon screws, I assume that stainless is not required.
I know Schlumberger as oil field related. You must be in another division and indoors to be able to use carbon screws with any success.
John,
I would like to suggest an interesting source of informations on screw finishes, the series of British standards BS 7371-1 [link by ed. to spec at TechStreet] to BS 7371-11 [link by ed. to spec at TechStreet], all standards dealing only with screw finishes.
You can get them to a reasonnable cost from the BSI in London UK and possibly at a reduced cost from the MFA (Metal Finishing Association) also in UK. I don't remember if the MFA offers this service to members only or to all. Address of the MFA is available through the homepage of www.finishing.com !
One word of introduction to these standards : BS 7371-1 [link by ed. to spec at TechStreet] is a general introduction to all screw finishes and to Torque/Tension. In the other parts you will find details about all coatings and finishes, with practical guidelines for the choice of the coating thickness and of the passivate in case of zinc electroplating.
Regarding contact with Aluminium, pure zinc will consume itself rapidly, I would suggest a coating made of zinc and aluminium flakes in a chrome binding matrix, providing controlled cathodic protection : see BS 7371-11 [link by ed. to spec at TechStreet].
Frederic Gheno
France
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
